03 durango a/c switch
Old Nov 22, 2010 | 06:27 PM
gldoyle's Avatar
gldoyle
Default 03 durango a/c switch
My a/c switch on a 2003 Durango quit working (snowflake won`t light up ) , and of coarse the a/c doesn`t come on . I`m sure it must be a fuse , but can`t locate it . Where should I look and if it`s not a fuse how would I check switch ? Thanks for any replys
Old Nov 22, 2010 | 06:35 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
sounds like a fuse, start by checking the fuse panel inside the drivers side door jam, and if nothing in there, then check the PDC under the hood, (black box just behind the battery on the drivers side of the truck) see if that fixes it and let us know if it doesn't
just a stupid question (im sure) where do you live that you are using A/C in November?
Old Nov 22, 2010 | 10:31 PM
gldoyle's Avatar
gldoyle
Thats not a stupid question at all `cause here in central Texas I have used the a/c in January because it may be cold today and HOT tomorrow , ya just never know .
Thanks about the fuses . I `ll try to check them tomorrow .
Old Nov 24, 2010 | 11:20 AM
gldoyle's Avatar
gldoyle
Just checked fuses in both places and they are all ok . What can I check next or do I just replace switch on dash ?
Old Nov 24, 2010 | 04:07 PM
hydrashocker's Avatar
hydrashocker
There is a relay in the PDC. Swap the relay with a different one of the same part number.
