Window Troubles
Old Nov 27, 2010 | 04:55 PM
Pax44's Avatar
Pax44
Good afternoon - Have a 2001 Durango on which the passenger side window switch has stopped working suddenly - The window can still be controlled from the driver side switch - Thinking switch when bad I ordere another and installed it - still not working - from Pass side - Any Suggestions as where to go next ? Tks Pax44
Old Nov 27, 2010 | 06:06 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
do the back windows work from the doors? if not then the master switch in the drivers door is bad if they do then you have a bad wire connection somewhere in the door, time to open it up and look around
Old Nov 27, 2010 | 06:47 PM
hydrashocker's Avatar
hydrashocker
Like Sharps said,
Sounds like a bad diode in the master drivers side switch or a bad connection.
Old Jun 21, 2013 | 07:49 PM
bigtony67's Avatar
bigtony67
my driver side window won't work but all the other ones work. any clues
Old Jun 22, 2013 | 12:20 AM
2kdurangoslt's Avatar
2kdurangoslt
any details on this bad diode?
