I read awhile ago how to reset the d other then unplugging the battery.anyone remember how to do this.
No,
if you don't disconnect the battery you could cause an "Arch" and that could fry your PCM. Anytime you play with anything the first thing you do is disconnect the negative cable and shield it away from any grounding! Simply DON'T DO IT! https://dodgeforum.com/forum/1st-gen...ine-light.html
