heated seats
Old Jun 11, 2005 | 04:22 AM
djripper's Avatar
djripper
Default heated seats
just wondering if anyone has had the problem of the drivers side heated seat not working on a 2001 Durango. If so any help or suggestions would be greatly appreciated.
Old Aug 13, 2005 | 08:16 PM
broman's Avatar
broman
Default RE: heated seats
Yes, I have had the same problem but, have not found the solution yet. I asked the dealership to look when I brought it in for the Upper Ball Joint recall. They took a quick look and couldn't find it. They wanted to charge more to look and it wasn't that big of a deal, so I let it go...
Let me know if find out and I'll do same.
Old Aug 14, 2005 | 08:15 PM
Digitoxin's Avatar
Digitoxin
Your heated seats have a element imbetween the seat cover and
cushion. First Check The Fuses... If you have a OHMs meter, look
for the (two wire) harness coming from the seat bottom cushion,
and seat back, (under the seat.) Check to see if you have continuity
through the elements, by disconnecting the wire, and putting the meter
on OMHs, and touching both wires. Do the bottom cushion, then the seat
back. The meter will show 0.00, or LO, or nothing , if there is a broken wire.
Seat heater elements are usually the cause of a heated seat to not work.
Hope this helps...
https://dodgeforum.com/albumphoto.as...Type=6&apage=7
Old Jan 30, 2006 | 11:11 AM
wiznkids's Avatar
wiznkids
Anyone find the problem with heated seats? Mine quit yesterday. It's identical to the others mention in this forum.
Old Dec 5, 2006 | 05:14 PM
joederr's Avatar
joederr
My drivers side has been inoperative for a while (some time last spring it quit) if you hit the button, it just blinks at you. I will take try to Ohm it out tonight or tomorrow.
