Help identify this hose
Old Jan 2, 2011 | 03:54 PM
Fangorious's Avatar
Fangorious
Default Help identify this hose
I have an '01 4.7 liter. I was replacing the spark plugs and when working on the rear-most passenger side plug a hose snapped. It's a very small diameter hose. I've taken some pictures: the area the hose occupies, the location of each end of the hose, the actual plugs on each end of the hose. The car starts without it, but I really don't want to drive to anywhere without knowing what it is.
Old Jan 2, 2011 | 04:15 PM
dolittle's Avatar
dolittle
Look like a vacuum hose to your cruse control.
It should not hurt to drive it. (see if the cruse works)
Old Jan 2, 2011 | 04:20 PM
Biff85ta's Avatar
Biff85ta
Looks like the vacuum line for the the cruise maybe. Pull the ned out of the connectors and shove the plastic hose back in them. If it isn't long enough you may have to look at replacing it or you could just cap it at the T and live without the crusie.
Old Jan 2, 2011 | 04:52 PM
Fangorious's Avatar
Fangorious
Thanks for the quick responses! The hose actually broke in several places trying to pull it all out to bring to a store. Looks like I can buy bulk hose so I'll bring in the ends and see what I can work out.
Old Jan 2, 2011 | 10:42 PM
hydrashocker's Avatar
hydrashocker
I too think it's for the Cruse Control.
You should be able to get one from the dealer.
Old Jan 3, 2011 | 12:08 AM
IndyDurango's Avatar
IndyDurango
It is the cruise control vac line. No "ifs" about it. 100% for sure from your photo below:
IndyD
