P0320 on my 2001 4.7
Old Jan 5, 2011 | 05:07 PM
Durangovaldeez's Avatar
Durangovaldeez
Default P0320 on my 2001 4.7
OK - so I got the following code:
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
Any suggestions on diagnosing?
Symptom: Engine almost acts like it is hitting a Rev Limiter.
If I get on the gas it is like accelerate, cut out, accelerate, cut out, etc, etc...
Thanks in advance
Old Jan 5, 2011 | 05:20 PM
Durangovaldeez
OK - so I see that the most likely causes are cam and crank position sensors.
Are there any write ups for where to find these babies hopefully with pictures?
Old Jan 5, 2011 | 06:08 PM
Durangovaldeez
I went and grabbed both sensors, AutoZone has what appears to be pretty good instructions. I'll let ya know.
Old Jan 5, 2011 | 07:53 PM
IndyDurango's Avatar
IndyDurango
Good luck valdeez. Let us know how it works out.
IndyD
Old Jan 5, 2011 | 09:07 PM
Durangovaldeez
SO I replaced the Crank position sensor so far - that sucked. The thing just disintegrated and I had to chip it away. Anyway - I finally got it out, put the new one in. I fired her up and took it for a ride and she seems to be running good. I'm gonna replace the Cam sensor tomorrow for good measure but it is snowing and cold here so I am quitting for the evening. Wahhh - I know.
I cleared the codes and so far the engine light has stayed out but I have only driven her a few miles sine replacing the sensor. I'll update tomorrow after work - that is a 52 mile R.T.
Once again - thanks to this forum I just saved myself some $$ and didn't have to let the D into someone elses hands. This forum kicks ***!
Old Jan 5, 2011 | 10:44 PM
hydrashocker's Avatar
hydrashocker
There are write ups if you search, either way glad you got it!
Old Jan 7, 2011 | 10:25 PM
Durangovaldeez
Sorry I didn't update yesterday!
Never got around to installing the CAM sensor last night., After 100 miles I would say the CRANK Sensor was the issue. I can spank that bbitch and she responds!
