Can I bypass my tccm? 01 durango
Old Jan 11, 2011 | 01:11 AM
1980superdave's Avatar
1980superdave
Default Can I bypass my tccm? 01 durango
My tccm went bad I think. I am having the exact same issues as others with my selector switch position indicator led's not lit and am not able to shift out of 2wd ect. How do I test it? where can I find a schematic for the tccm? Is there a way to bypass it by either adding a jumper wire or installing a switch?
Old Jan 11, 2011 | 10:06 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
nope, no way to bypass it, if its gone you need to replace it
this pdf should have the wiring diagram for the tccm, i have never seen a diagram for the interior components of the tccm tho
http://www.mediafire.com/?2cg2hgim2zz
Old Jan 11, 2011 | 10:42 AM
Dans01Durango's Avatar
Dans01Durango
Best bet is to go to the junk yard and take the tccm or switch from a similar 01 D.
Old Jan 11, 2011 | 12:49 PM
1980superdave
Yeah Im not looking for a bypass to eliminate it, although that would be nice. I just need something that will put it in to 4hi for a day or too in case i need to go any where of if i need to get to work. I'm currently enjoying a rare snow and ice storm down here in Georgia and unable to get it out of the driveway in 2hi.
Old Jan 11, 2011 | 03:26 PM
shrpshtr325
THE ULTI-MOD
you might be able to get it into 4hi by applying 12 volts to the t-case motor, but that requires crawling underneath the truck and finding the switch motor and a 12v power supply (and i have NO clue how you would tell if it was in 4hi or not)
Old Jan 12, 2011 | 11:16 AM
1980superdave
That is not a bad idea. I may be able to find which lead going to the shift motor gives the 4hi shift command.
Old Jan 13, 2011 | 12:32 PM
hydrashocker's Avatar
hydrashocker
We just did a big write up on this topic. https://dodgeforum.com/forum/1st-gen...em-thread.html
