New from North Alabama
Old Jan 24, 2011 | 10:33 AM
mixman's Avatar
mixman
Default New from North Alabama
2000 Durango 5.2L. I was wondering if anyone could point me in the right direction. I have been getting P0132 error code. I replaced the upstream O2 sensor with one purchased at the Dodge Dealer but the code keeps coming back. The vehicle runs really rough, stalls and jumps. Any idea on what to try next?
Old Jan 24, 2011 | 01:08 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the first generation Durango section. Check out the link below:
http://www.obd-codes.com/p0132
FF
Old Jan 24, 2011 | 03:52 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
take a look to see if your powersteering pressure switch is leaking, if it is you could have power steering fluid leaking into the wire harness and this can cause codes and problems related to the sensors
Old Jan 25, 2011 | 03:37 PM
mixman's Avatar
mixman
Thanks, i did find a powersteering leak in the vincity of the pump. Is the switch in the pump?
Old Jan 25, 2011 | 04:30 PM
shrpshtr325
THE ULTI-MOD
im not sure where it is on the 5.2/5.9, but im sure someone else will post up with the exact location for you
Old Jan 25, 2011 | 11:10 PM
hydrashocker's Avatar
hydrashocker
It's on the pressure side line.
