Overdrive button
Old Jun 20, 2005 | 06:53 PM
dante0's Avatar
dante0
Default Overdrive button
Hi i have a Durango SLT 1998 5,2 and when a drive on a hiway a dont fell the diffrens when a press in the overdrive butten and the lamp never comes on the display, is it normal or dont a have a overdrive on this modell????
Old Jun 20, 2005 | 09:26 PM
Last Of The R/Ts's Avatar
Last Of The R/Ts
Default RE: Overdrive button
If there is a button for it on the end of your gear shift lever, you should have it regardless. Do you see a difference in RPM's when you press the button? If you do not then there is definately something wrong.
Old Jun 21, 2005 | 05:56 PM
dante0's Avatar
dante0
No no difrenns on rpm when a press the butten
