1998 Durango Frame
I have a 1998 Durango, i need to know is the frame on the front of it the same as the front of a Dakota? I'm putting a plow on and need to know if the frame for the plow will fit. Thanks.
i believe the durango shares a frame w/ the regular cab dakota.
however i will point out that plowing with these trucks is a bad idea, you WILL be breaking stuff very quickly. anything with independent front suspension is not designed for plowing and will most likely cost you more than buying something with a solid front axle.
im NOT saying dont do it, im just saying be prepared for the increase in repairs if you do decide to go through with it.
