2000 5.9 won't start
Old Feb 9, 2011 | 05:03 PM
Jay Lewis's Avatar
Jay Lewis
Default 2000 5.9 won't start
I have a 2000 5.9 4x4 and it will not start. When I turn the key in the ignition, all I hear is a single *click* and then nothing. Not even the slightest bit of turning over. The battery is good, the starter is good, connections are good, fuses and relays are good. Any ideas?
Old Feb 9, 2011 | 06:22 PM
samnbensdad's Avatar
samnbensdad
Sounds like a connection is NOT good. Do your headlights, dome light, radio, etc work? Have you actually tested the starter and battery? Are you certain your battery has a good ground?
Old Feb 9, 2011 | 07:00 PM
WhiteWidow00's Avatar
WhiteWidow00
Check starter relay in PDC. Swap it out with one thats the same.
Old Feb 9, 2011 | 08:26 PM
Jay Lewis's Avatar
Jay Lewis
Yes.
Yes. I've pulled both of them out and had them tested.
How so?
I did that as well.
Old Feb 9, 2011 | 08:34 PM
WhiteWidow00
If your accessories work and the starter is clicking it's most likely a starter problem.
Old Feb 9, 2011 | 08:44 PM
samnbensdad
When you turn your key, and you instrument cluster lights up, does your voltmeter jump to 12'ish volts?
Another thought... make sure your truck is in park or neutral. Try playing with the shifter.
Old Feb 10, 2011 | 10:05 AM
Dans01Durango's Avatar
Dans01Durango
Neutral safety switch: located on the outside of the tranny, three wires leading to it.
Old Feb 10, 2011 | 10:26 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
dan has a good idea if the starter tested out good
Old Feb 11, 2011 | 12:24 AM
hydrashocker's Avatar
hydrashocker
Most likely a bad connection at the battery. If you double clean them with the same issue then most likely it's the starter.
Check your battery cables as well.
You can also have someone try to turn it over and feel the relay in the PDC to see if that is the actual "clicking" you hear. If it is, look for power down at the coil on the starter. If no power then you have a short between the relay and the starter. Personally, it sounds like a starter.
