Blower motor & Resistor
Old Feb 28, 2011 | 10:13 AM
jthiggins33's Avatar
jthiggins33
Default Blower motor & Resistor
I have no idea what to do. I installed a new blower motor and replaced the blower resistor 3 times...it continues to stop working intermittantly until i wiggle the wire harness where the resistor is. the last resistor i replaced when i replace the motor the same time looked like it was burnt where the connector plugs into it. do I need to replace the whole harness?
Old Feb 28, 2011 | 11:05 AM
Dans01Durango's Avatar
Dans01Durango
Yes, the burnt harness will continue to ground out the resistor until you replace the whole harness.
Old Feb 28, 2011 | 12:19 PM
hydrashocker's Avatar
hydrashocker
Replace the harness.
You can buy a new harness from the dealer that is an upgraded heavy duty one, or get a new one from a junk yard. You will have to splice it in either way.
Old Feb 28, 2011 | 03:13 PM
coreybv's Avatar
coreybv
When you splice the harness in, do yourself a huge favor and do it right.
Solder the wires rather than just twisting them together, and use shrink tube rather than just wrapping them with electrical tape.
It's more work but will result in a permanent repair instead of something that you'll have to redo in a couple of years.
Old Feb 28, 2011 | 03:15 PM
jthiggins33
i got the new one from the dealer but is there a sepcial tool for the connecter? and the new kit came with different color wires than the original in the truck. one set of wires has gold connectors and the other set of new wires has standard silver connectors
