2001 4.7 Durango HELP
Old Mar 5, 2011 | 08:03 PM
svfd757's Avatar
svfd757
Default 2001 4.7 Durango HELP
Need some help. Durango died a week or so ago. Bought a code reader and it kicked out the following...
P0031 HO2S Heater Control Circut Low (Bank 1 Sensor 1)
P0037 HO2S Heater Control Circut Low (Bank 1 Sensor 2)
P0132 O2 Sensor Circut High Voltage (Bank 1 Sensor 1)
P0138 O2 Sensor Circut High Voltage (Bank 1 Sensor 2)
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
P0601 Internal Control Module Memory Check Sum Error
Replaced O2 sensor on exhust. Replaced ECM. Changed Spark Plugs. Turns over but will not start Please Help!!!
Old Mar 5, 2011 | 08:52 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
with all those codes it looks like the pcm is probably shot
uhh yea, you need a PCM, $200 on ebay, plug and play you give them your vin #, they program it and ship it out
Old Mar 6, 2011 | 08:53 PM
hydrashocker's Avatar
hydrashocker
+1 Replace the PCM.
Old Mar 6, 2011 | 09:39 PM
CharlieEscobar's Avatar
CharlieEscobar
I just got one from American Computer Exchange, $200 plus $50 for overnight. I ordered it at 4PM and got it at 10am the next day. They're in Florida and I'm in Arkansas.
They'll ask for your vin# and mileage, 4wd, etc.
You can ask them tech questions on what is happening with your d and those people know their business.
Old Mar 6, 2011 | 10:02 PM
WhiteWidow00's Avatar
WhiteWidow00
Replaced ECM.
Hmmm... Did you replace the CTM or PCM. Have to ask because people get them mixed up constantly, and they're simply not the same.
Yeah if you ever get enough codes you need a pen and paper to write them all down, its more than likely the PCM.
