99 5.2 4x4 4:56 gears
Old Mar 7, 2011 | 12:18 PM
durango12's Avatar
durango12
Default 99 5.2 4x4 4:56 gears
I am wondering the price range for 4:56 gears for front and rear diff with all new bearings would cost? Im getting a bonus at the end of the month and will have it done so im just doin my research
Old Mar 7, 2011 | 01:38 PM
hydrashocker's Avatar
hydrashocker
I just paid $1500 for 4:10's both front and back with Yukon gears and bearings. Now mine is not the same axles as yours, but I got a kick *** deal because eveyone was in the $2,000+ dollar range. However my parts are twice the costs of yours.
So In my opinion, you will be around $1200-$1500 to get both front and rear done. If you shop around people are willing to wheel and deal right now. You could price out the R&P kits and a master kit for each axle and see if someone will just install them as well, that will cost you less.
Old Mar 7, 2011 | 02:36 PM
WhiteWidow00's Avatar
WhiteWidow00
Hydra gve you some good numbers. That sounds good to do both axles. I'm also about to put 4.56 on my back axle.
Old Mar 12, 2011 | 06:31 PM
durango12's Avatar
durango12
also is my front diff dana 35 27 spline?
Old Mar 12, 2011 | 06:36 PM
gr8scott72's Avatar
gr8scott72
Prices around here are right at $800 per axle.
Old Mar 13, 2011 | 03:03 PM
hydrashocker
I think your front is a 194 FIA, but it's like a Dana 35 because it was built by Dana.
http://www.ringpinion.com/DiffDetail...&DriveType=4WD
You should get a build sheet from the factory just to ensure which one you have.
