O/D off help!
Old Mar 25, 2011 | 02:50 PM
hydrashocker's Avatar
hydrashocker
Either you have a bad switch on the column or you have a bad switch or short on the transmission. Get under it and unplug it and plug it back in (drivers side) and look for corosion or contamination.
One way to help you rule it out is to remove the switch in the column. Just pop the outside ring off and pull the switch out. Then drive it and see if it stops or not. While the switch is off check for grounding wires and such.
Old Mar 25, 2011 | 04:08 PM
Winsok's Avatar
Winsok
so i took the ring off it, pulled on the little button that was coming out and a little click looking thing came out, and it had a little housing, but it is just a little button with 4 metal clips or prongs in the end is this right? or did i miss more. sorry dificulty describing it.
Old Mar 25, 2011 | 06:40 PM
hydrashocker
Sounds right:
In the 2003 Dakota Service manual it states this on page 21-219:
REMOVAL
(1) Using a plastic trim tool, remove the overdrive
off switch retainer from the shift lever (Fig. 134).
(2) Pull the switch outwards to release it from the
connector in the lever (Fig. 135)
INSTALLATION
NOTE: There is enough slack in the wire to pull out
the connector from the lever.
(1) Pull the connector out of the lever just enough
to grasp it.
CAUTION: Be careful not to bend the pins on the
overdrive off switch. Use care when installing the
switch, as it is not indexed, and can be accidentally
installed incorrectly.
(2) Install the overdrive off switch into the connector
(Fig. 136)
(3) Push the overdrive off switch and wiring into
the shift lever.
(4) Install the overdrive off switch retainer onto
the shift lever.
I checked the 2002 Durango Servince Manual and it states the same thing page 21-271:
REMOVAL
off switch retainer from the shift lever (Fig. 128).
connector in the lever (Fig. 129)
Fig. 127 Overdrive Off Switch
Fig. 128 Overdrive Off Switch Retainer
1 - GEAR SHIFT LEVER
2 - OVERDRIVE OFF SWITCH RETAINER
3 - PLASTIC TRIM TOOL
DN AUTOMATIC TRANSMISSION - 46RE 21 - 271
OVERDRIVE CLUTCH (Continued)
INSTALLATION
to grasp it.
(Fig. 130)
the shift lever.
the shift lever.
You can download the manual here and it has pictures as well: http://www.mediafire.com/?sharekey=c...589d1986ba#0,1
