01 Durango runs hot when towing or hill climbing
For the past 3 years my dingo gets hot when towing or climbing hills. I got the radiator checked replaced water pump and still continues to run hot. Has any else had this problem? What did u do to fix it? Any suggestions?
Thanks, Sid
Thanks, Sid
It normally runs a little past half and when towing pushes it almost to red. I had to pullover once or twice cause the light comes on n forget bout running the ac. My fan works I wonder if could be the tranny cooler?
check the clutch fan, make sure the clutch is good, spin it by hand w/ the engine off and see how far the fan spins before stopping, more than 1/2 a turn and the clutch is shot
otherwise get an ir non contact thermometer and check for hot spots in the radiator
It Could be a bad Stat.
I just changed out my Stat and replaced the riser and cap. A 180 went in to replace the 195. Running cool is not an issue in Southern NM. I was running well while towing on the flat, but any hill pushed my temp gauge way up. I figured the stat was replaced with a higher temp one since my D just got relocated from Colorado, but it was a 195 and did not open when I tested it. Things are running well with the new stat without towing, and I'm hoping that while towing will be the same story.
