99 durango lift and tire size question
Old Mar 30, 2011 | 10:21 PM
Will.Keating's Avatar
Will.Keating
Default 99 durango lift and tire size question
hey i have a 1999 4wd automatic 5.9 V8 durango and this is what im doing:
TS lift - 2" = $35
Body Lift - 3" = $300
32x11.50r15 = $700
^will this tire size work on the stock rims (i believe there 15) and will this tire size fit in nicely without any rubbing or trimming needed?
thanks!
Old Mar 30, 2011 | 10:26 PM
WhiteWidow00's Avatar
WhiteWidow00
11.50 is a bit more wide than the stock wheels like but yes it will fit. Also with that lift you'll be just fine and as long as it's not more than 11.50 you shouldn't rub at all. If anything you'll rub just a hair at full turn but just rubbing the plastic and nothing more.
Old Mar 31, 2011 | 12:41 AM
Will.Keating
do you think i could manage 33x12.50... would the rims work ...and if so would it all fit? thanks
Old Mar 31, 2011 | 08:32 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you need 5" of total lift to fit 33x12.5s w/o rubbing, your rims can handle it, but you dont have the clearance to fit that big of a tire with your setup
