Check Engine Light Code PO308 and PO445
Old Apr 13, 2011 | 11:46 PM
topdogcustoms's Avatar
topdogcustoms
i had the same code right in front of the gas tank theres a couple of hoses i will bet one has a crack in it i paid 7 dollars from the dealer and it took 2 minutes to do the longest part was jacking the D up so my A$$ would fit under it
Old Apr 14, 2011 | 12:23 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
check the FAQ thread under evap leaks and there is a write up in there, the evap canister hoses are notorious for throwing evap leaks of all sizes
Old Jun 10, 2011 | 08:42 PM
MRob11's Avatar
MRob11
I'm going to fix this P0455 thing (hopefully) by replacing the hoses down by the gas tank that go into the EVAP canister. Also I'm going to Autozone and I'm going to get a new purge solenoid. A mechanic I know suggested that and I've read about that. So... I knoe its under the fuse box by the battery but I have no clue about how to replace it and want to do it myself. Any suggestions on how to do it??? It doesnt look like the fuse box will come out easy because all the wires.
Old Jun 10, 2011 | 10:27 PM
shrpshtr325
THE ULTI-MOD
try the hoses first and clear the code, if it comes back then change the solenoid, my .02 so you dont spend money you dont have to
Old Jun 10, 2011 | 10:33 PM
MRob11's Avatar
MRob11
Ya true. I read that Napa Auto Parts has the 2 hoses for $5. They arent made really for Dodge but they look the same. I'll check the sizes of them but I bet they're all the same. Thanks
Old Jul 18, 2011 | 04:56 PM
MRob11's Avatar
MRob11
I solved the problem! Theres a small hose that goes into a solenoid or something in the front of the engine compartment on the drivers side. It split and fell off. There was enough hose so that I could cut it and reattach it. Cleared the code and passed inspection.
