vibration in my 5.9
Old Apr 8, 2011 | 12:27 AM
hydrashocker's Avatar
hydrashocker
Sounds like a plenum gasket or intake manifold gasket.
Old Apr 8, 2011 | 01:07 PM
WhiteWidow00's Avatar
WhiteWidow00
Originally Posted by bossdog02
I also changed the plenum gasket
This is why I overlooked the plenum gasket hydra. However thinking about it, if you went with another stock plenum gasket, this could be the problem again. If this is the case again, go with a Hughes Plenum Kit. This is always what you should do to anyone seeking further advice on the subject also, never go with a stocker.
http://www.hughesengines.com/Index/p...p?partid=26190
Old Apr 8, 2011 | 05:54 PM
bossdog02's Avatar
bossdog02
Thanks for all your help. I will try to do a leak down test this weekend and I will keep you posted on what I find.
Old Apr 9, 2011 | 02:00 AM
bossdog02's Avatar
bossdog02
I did purchase the Hughes plenum cover and gasket. When I pulled the old plenum gasket it was not blown out at all, I still changed it out though.
Old Apr 24, 2011 | 09:23 PM
bossdog02's Avatar
bossdog02
For those who need answers later, I found the cause of my vibration. It was my harmonic balancer. Its neat how you ask for information about a certain issue and give all the info you can and then people try to fix other issues other than the one you posted about.
Old Apr 25, 2011 | 06:09 PM
hydrashocker
Ya,
Things tend to get off topic sometimes.
