2000 Error Codes - Idle jumping up and down
Old Jul 3, 2005 | 08:17 PM
fcastro's Avatar
fcastro
Default 2000 Error Codes - Idle jumping up and down
Hi everyone having some issues with my 2000 durango. I noticed that my rpm started kinda bouncing up and down when I was on the highway the other day when I was near my house the check engine light came on. Seems like the engine was pushing the rpm higher then it needed to. I got the following error codes P0205, P0207, and P0208.
My truck has 63,000 miles on it. Anyone out there know what the problem could be? The codes are pointing to injector control circuit problems with cylinders (5-6-7)
Old Jul 22, 2005 | 02:41 PM
hangnx's Avatar
hangnx
Default RE: 2000 Error Codes - Idle jumping up and down
what did you find on the cause of your p205 p206 codes i am having same trouble but dealer wanted to replace all injectors and rail. i pulled rail cleaned injectors and rplace injector 5 and 6 . cleaned rail and put old rail back on.still have MIL light that wont clear. but for a few miniutes and engine still runs a little rough. i have a 2000 5.9l durango 57000 miles
Old Jul 23, 2005 | 06:42 AM
Dave in LB's Avatar
Dave in LB
I'm having a similar issue but the codes came back as input sensor problem and the dealer will be replacing that next week. Hope there aren't injector issues, I haven't had the ride that long.
