ac not working
Old May 10, 2011 | 08:51 PM
xander_crews's Avatar
xander_crews
Default ac not working
so I swapped the motor out in my durango and now the AC will not turn on. the clutch will lock in from what I can see.
any idea's of where I could have missed a wire or something?
1998 durango, 5.2, 4wd
Old May 10, 2011 | 09:42 PM
WhiteWidow00's Avatar
WhiteWidow00
Check relay in the PDC first and then check to ensure the connector at the compressor is firmly seated and not loose.
Old May 10, 2011 | 11:39 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
im assuming you managed to not open up the a/c system, but if you did it needs to be vaccumed down, and make sure it HOLDS vacum, before recharging w/ the correct refrigerant mass and correct amount of compressor oil
if the a/c clutch is engaging it SHOULD be getting cold unless you have a jammed blend door in the cabin, or a bad vacum line running into the firewall to control the doors.
Old May 12, 2011 | 03:59 AM
xander_crews
yeah I missed a word, I meant to say it will not lock in. and yeah it was left sealed the entire motor swap
Old May 12, 2011 | 10:26 AM
shrpshtr325
THE ULTI-MOD
if the compressor doesnt even engage my first check would be the relay for it, simplyswap it with one of the same number, if that doesnt do it i would have a shop hook up some gauges cause it sounds like its probably out of refrigerant.
