Rear Heat.
Old May 17, 2011 | 08:20 PM
justin101's Avatar
justin101
Default Rear Heat.
2001 Dodge Durango 5.9. So my heat in the front is very hot(hotter than my moms brand new impala) but if i turn on the rear heat you can feel less air blow out of the vents in the rear then if it were set to cold and the air isn't warm at all. Any ideas?
Old May 17, 2011 | 09:35 PM
pkucan's Avatar
pkucan
Originally Posted by justin101
So my heat in the front is very hot but if i turn on the rear heat you can feel less air blow out of the vents in the rear
Possible blockage or blower is on its way out?
Not sure I understand this part?
Old May 17, 2011 | 10:57 PM
hydrashocker's Avatar
hydrashocker
I can't follow the questions.
Old May 18, 2011 | 03:17 PM
Groggy's Avatar
Groggy
The vents in the back of the center console are controlled by a lever that connects to a plastic connector. Take the box out of the center console and make sure it's still connected. Gravity does pull items into the deflector that blocks air off, sends it to the floor, or to the top of the console. Hope that helps...
BTW, If you have ceiling mounted air for the back, it does not supply heat.
