Need help about speaker wiring
Old Jul 6, 2005 | 10:46 PM
ironman22's Avatar
ironman22
Default Need help about speaker wiring
I need some help about what color wire is the rear speakers im trying to put 12" speakers in 2004 durango. Ive found the speaker wires and other wires under the inside door frame just need help on wich color is wich if you could thanks
Old Jul 26, 2005 | 12:25 PM
KyferEz's Avatar
KyferEz
Default RE: Need help about speaker wiring
I do not recommend using the existing wiring for any aftermarket installation. It is important to rewire using a larger guage when using larger or more powerful speakers. Also, you likely will find that the head unit will not drive the 12" speakers well at all. If these 12" are subwoofers, you will barely hear them. If they are home boxes (or similar) you will likely find you have better sound from the stock speakers unless you add amplification.
Here is what I was able to find out:
Left Front Tweeter- + Gray/orange Stripe - Gray/yellow Stripe
Right Front Tweeter- + Gray/dark green stripe - Gray/light green stripe
Left Front Door- + Gray/violet stripe - Gray/yellow
Right Front Door- + Dark Green/violet - Dark Green/Yellow
Right Rear/Plus tweeter(same wires)- +Dark Green/Light Green - Light Green/Gray
Hope that helps,
KyferEz
Old Jul 26, 2005 | 10:55 PM
Dr.Dodge's Avatar
Dr.Dodge
Here are the wiring diagrams for both the premium and the base stereos in the Durango.
Jeff
[IMG]local://upfiles/13007/ED36460C1363451DA250F48E45DB6904.jpg[/IMG]
[IMG]local://upfiles/13007/E372ACF0B4DE41E4A0057E43CF3DCC7B.jpg[/IMG]
