Question about front drve shaft...
Old May 19, 2011 | 09:19 PM
CP.reaper911's Avatar
CP.reaper911
Default Question about front drve shaft...
I was able to get the front drive shaft failry easy and noticed the yoke on transfer case side is bad. I also noticed that on both couplings, the was a nut holding the couplings to the front differential and one holding the coupling for the transfer case.
Would it hurt to leave this shaft off until it is repaired?
Old May 19, 2011 | 10:05 PM
samnbensdad's Avatar
samnbensdad
Do a search. There are lots of opinions.
Old May 20, 2011 | 12:43 AM
hydrashocker's Avatar
hydrashocker
Yes you can, but you need to fix the problem.
