Installing Cold Cathodes
Old May 26, 2011 | 06:16 PM
DSWALLS's Avatar
DSWALLS
Default Installing Cold Cathodes
2001 Durango SLT 4.7L and I want to install cold cathodes under the dash, where would be a good place to tie into a 12V power supply, that either comes on when the dome light does or when I start the truck.
Thanks
Old May 27, 2011 | 02:04 PM
hydrashocker's Avatar
hydrashocker
Well I would most likely tie into the fuse box in an un-used slot and put in a 15 amp fuse and place it in a ignition switched power supply, or tie into the headlight switch with a relay system.
