A/c prob.
Old Jun 1, 2011 | 10:32 AM
durango_boy1999's Avatar
durango_boy1999
Default A/c prob.
Ive check fuses relays put jumper in place of relay and compressor came on took out jumper and it stop working tried differnt relay in it still didnt work my manual says to look for an open circuit between the pcm and relay.ANYTHING EASIER this sht is getting old
Old Jun 1, 2011 | 11:06 AM
WhiteWidow00's Avatar
WhiteWidow00
Did you check the system to make sure there is enough freon running through it? This is the number 1 cause for the compressor not kicking on, but kicking on being jumped.
Old Jun 1, 2011 | 11:38 AM
durango_boy1999
thanks thats my next step I can get it to come on with a jumper where the relay is though does that sound to be the prob because its nice and cold when i do it that way
Old Jun 1, 2011 | 02:18 PM
WhiteWidow00
Yep, more than likely there's not enough pressure in the system to kick the clutch automatically. Even though it's nice and cold, doesn't mean it's cooling to its maximum potential and doesn't always mean there's not enough freon in there!
Old Jun 1, 2011 | 11:15 PM
hydrashocker's Avatar
hydrashocker
I would have the A/C serviced.
