transfer case maintenance
Old Jun 21, 2011 | 04:34 PM
  #21
srch4me's Avatar
srch4me
Originally Posted by Old_School
You will find 2 plugs on the right side of the case top one is the fill plug bottom is the drain plug...
awesome... thanks old_school!
Old Jun 21, 2011 | 05:54 PM
  #22
pkucan's Avatar
pkucan
Originally Posted by srch4me
i think i have.... only thing i need to know is how to drain and fill it... is there a plug on it or do i have to unbolt the case
One thing I've read somewhere that makes a lot of sense. Take out the fill plug first because if you drain it and then can't get the fill plug out you are SOL.
Old Jun 22, 2011 | 01:59 AM
  #23
srch4me's Avatar
srch4me
ok... ill keep that in mind
Old Jun 22, 2011 | 03:38 PM
  #24
Old_School's Avatar
Old_School
Your not totally SOL...you can still drive it just can't use 4X4 till you get the plug free and fill it...
Old Jun 22, 2011 | 03:42 PM
  #25
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
wrong, you ARE SOL bc the t-case contains moving parts(even when driving in 2wd) that will only last for a very short period of time w/o lubrication.
Old Jun 22, 2011 | 04:32 PM
  #26
hydrashocker's Avatar
hydrashocker
Moving parts need lubrication.
Old Jun 22, 2011 | 04:50 PM
  #27
srch4me's Avatar
srch4me
Originally Posted by hydrashocker
+1
HAHA +1, all moving parts need lubrication is so true
Old Jun 24, 2011 | 06:01 AM
  #28
70Cuda4Speed's Avatar
70Cuda4Speed
You will find that filling the transfer case with new fluid is a real PITA. There simply isn't very much vertical headroom between the fill port and the bottom of the Durango body. I ended up getting a small funnel and forced some tubing over the end of it. This allowed me to hold the funnel upright enough to pour into it.
Recently I saw where someone had poured the fluid into a zip lock bag, zipped it shut, and then clipped off a corner of the bag. Apparently the idea is to shove the clipped corner into the fill port and squeeze the bag to transfer the fluid. I've never tried this, but it might work.
Old Jun 24, 2011 | 08:44 PM
  #29
Old_School's Avatar
Old_School
When i was gonna change mine i went to the scrapyard and found a 88-98 Chevy Silverado and pulled the washer fluid tank... They have the motor for the washer built right into the tank. i filled it up with the correct fluid and put the hose from the tank in the plug hole... hooked it up to a 9v battery and filled her right up.... sure it sounds like a cheesey redneck idea and you can only run the motor in short periods but, hey it works.....
Just make sure to clean out the bottle with soap and water and run some though the pump too.... You can also use it to fill the front and rear axles that way.
Old Jun 24, 2011 | 11:07 PM
  #30
70Cuda4Speed
Redneck or not, that's awesome!
