compression on a 5.9L
124k miles on the 5.9L is NOT a lot of miles really.
CYLINDER COMPRESSION PRESSURE TEST
The results of a cylinder compression pressure test
can be utilized to diagnose several engine malfunc-
tions.
Ensure the battery is completely charged and the
engine starter motor is in good operating condition.
Otherwise, the indicated compression pressures may
not be valid for diagnosis purposes.
(1) Clean the spark plug recesses with compressed
air.
(2) Remove the spark plugs.
(3) Secure the throttle in the wide-open position.
(4) Disconnect the ignition coil.
(5) Insert a compression pressure gauge and rotate
the engine with the engine starter motor for three
revolutions.
(6) Record the compression pressure on the third
revolution. Continue the test for the remaining cylin-
ders.
Cylinder Compression 689.5 kPa
Pressure (Min.) (100 psi)
Compression Ratio 9.1:1
Firing Order 1–8–4–3–6–5–7–2
Happy to help,
IndyDurango
tions.
air.
revolutions.
ders.
Happy to help,
IndyDurango
