Overheating
Old Jun 30, 2011 | 07:24 PM
dsm3069's Avatar
dsm3069
Default Overheating
I have a 2001 4.7L V8 Durango. Had my serpentine belt changed as well as water pump, upper and lower hoses, and thermostat. Temp gauge was past half-way mark on short drive home. The fan was on, but gauge didn't seem to drop much. Does the new thermostat need time to adjust, or could there be another problem?
Old Jun 30, 2011 | 07:59 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
did you burp the system properly?
also is your clutch fan working properly? give it a spin by hand, if it goes more than 1/2 a turn the clutch is shot.
Old Jun 30, 2011 | 08:28 PM
dsm3069's Avatar
dsm3069
Had my truck worked on at RS Strauss. Mechanic said clutch fan was working ok. If it happens tomorrow will take it back to them.
Old Jun 30, 2011 | 08:39 PM
Old_School's Avatar
Old_School
First thing i learned was never trust a shops word that if something works okay or not.... Sure there are some "Honest" Mechanics out there but, there far and few between.. I would test the clutch fan yourself only takes a few seconds then, if its not "ok" id take it back and call then on it.
Old Jun 30, 2011 | 09:04 PM
neilb's Avatar
neilb
There is not that much to a cooling system, and it seems like you have replaced most of it, I dont know about the 4.7 but on the 5.9 there is a small pipe from the system to the expansion tank, and if it is gunged up it can cause overheating problems, and it is often overlooked, if you have that take it off and blast some air through it, I did a complete cooling system service with a new rad, T stat etc, but it still over heated till I cleared that little insignificant piece of rubber pipe. Maybe this is a useless post cos you have the 4.7, but maybe not, good luck.
Oh, and yes to what they said.
Old Jun 30, 2011 | 10:19 PM
shrpshtr325
THE ULTI-MOD
4.7 still needs to have that pipe so not a useless post at all
Old Jun 30, 2011 | 10:33 PM
neilb's Avatar
neilb
Thanks, hope it helped, cos we are all in this together, and must keep our sticks on the ice ! lol
