key stuck in ignition, engine running
Old Jul 19, 2011 | 08:08 PM
emubird's Avatar
emubird
Default key stuck in ignition, engine running
2000 durango, 5.9, rwd.
key is locked in the "run" position and can't be turned to "off" even with car in park. the key CAN be turned to START... please don't ask how i know this :| Even tho car is running, most of the electrical systems are off: power windows/door-locks/stereo/ac etc... ABS and AIRBAG lights on. gages seem to be reading correctly. keyfob lock/unlock buttons working. auto transmission not shifting correctly.
dealer says <expensive> key cylinder assembly replacement will fix. i was hoping for just a fuse...
thoughts? thanks!
Old Jul 19, 2011 | 09:49 PM
hydrashocker's Avatar
hydrashocker
Sounds like a bad key switch. Try and move the steering wheel from side to side and see if it will turn off.
