Transmission Problem.
Old Jul 21, 2011 | 10:09 AM
justin101's Avatar
justin101
Default Transmission Problem.
So I get in my D the other morning and drive off to work and everything was fine. When i got to leave the parking lot at lunch I put it in reverse and gave it some gas and the transmission is slipping so bad in reverse, but it still able to back out. Also there was some vibration when i backed out that i normally never felt. I drive around and all my forward gears are fine. No slipping, vibration, or hesitation. So my question is what would it be?
Old Jul 21, 2011 | 11:28 AM
adukart's Avatar
adukart
I would check the trans fluid first. Look at it and smell it. If it is black and smells burned it needs to be changed badly. In my experience if it is really low this can happen to.
Old Jul 21, 2011 | 11:47 AM
hydrashocker's Avatar
hydrashocker
Could have broken the band or finished off the lineings. You could try to tighten up the reverse band slightly on your 46RE transmission. Don't forget to replace the filter while your in there and hope. Also look at your magnet and clean it off and look for anything that could have broke.
REAR BAND
The transmission oil pan must be removed for
access to the rear band adjusting screw.
(1) Raise vehicle.
(2) Remove transmission oil pan and drain fluid.
(3) Loosen band adjusting screw locknut 5-6 turns.
Be sure adjusting screw turns freely in lever.
(4) Tighten adjusting screw to 8 N·m (72 in. lbs.)
torque (Fig. 73).
(5) Back off adjusting screw 2 turns.
(6) Hold adjusting screw in place and tighten locknut
to 34 N·m (25 ft. lbs.) torque.
(7) Position new gasket on oil pan and install pan
on transmission. Tighten pan bolts to 13.6 N·m (125
in. lbs.) torque.
(8) Lower vehicle and refill transmission with
Mopar
t ATF +4, Type 9602 fluid. (about 6-8 quarts)
