No fan Hi speed...
Old Jul 26, 2011 | 08:59 PM
harleytech's Avatar
harleytech
Called my local Dodge Dealer and the resistor is only 7 Bucks...I would like to get the dealer part if and when I can,Just how I am. But Thanks anyway...! They have the harness/connector too.
Old Jul 27, 2011 | 12:19 PM
SyntheticBlinkerFluid's Avatar
I hope the one from the dealer is not the same junk one that is from the factory. All the aftermarket units are a much better design than the factory unit.
Old Jul 27, 2011 | 12:29 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the dealer (and factory now) use a much better (beefier looking) resistor than the one that came in the truck at manufacture, its cheap at the dealer so just go to them and get it
Old Jul 27, 2011 | 06:37 PM
harleytech's Avatar
harleytech
Talking
+1
Old Jul 27, 2011 | 06:46 PM
samnbensdad's Avatar
samnbensdad
Take a close look at the harness. I have the same setup as you. When mine went out, it fried one of the wires and basically welded the leads to the resistor. Also, it looks like a quick, simple job, but the screws are in tight locations. I almost felt like a contortionist.
Old Jul 27, 2011 | 10:50 PM
harleytech's Avatar
harleytech
Yeah, I need the harness/connector. Mine's welded to the resistor too....
Old Jul 28, 2011 | 10:54 AM
Bobman's Avatar
Bobman
+1 on that, although AutoZone sold me my last one with a lifetime warranty for $12. I've already replaced it once after 18 months of use, so it's been $6 times each so far!
FWIW, I think part of the problem with the connector welding on might be because the resistor mounts upside down and condensation forms in the base of it, leaking onto the contacts over time. I put some dielectric grease on the connector when I replaced mine and it unplugged much easier during replacement. Not that $35 is a lot for a connector, it's just a pain in the *** (literally!) to change it out.
Bob
Old Jul 28, 2011 | 09:32 PM
harleytech's Avatar
harleytech
I was gonna do that too...with the dielectric grease that is...
Old Jul 30, 2011 | 12:46 PM
harleytech's Avatar
harleytech
Talking
Well I installed the new resistor today w/new harness and connector and it works flawlessly. Got hi-speed again...yeah...!
Thanks again guy's..
Old Jul 30, 2011 | 04:04 PM
hydrashocker's Avatar
hydrashocker
Yep,
Put it on our pay checks!.....
