Old Aug 5, 2015, 07:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior
Print Wikipost
Mirror, mirror, what the hell--help!
Old Jul 22, 2011 | 11:39 AM
stonebridge's Avatar
stonebridge
Question Mirror, mirror, what the hell--help!
Is it possible to replace JUST THE MIRROR on a Dodge Durango 1999 driver's side without replacing the entire mirror casing and taking the door cover off? I have unheated power mirrors, one which was cracked on the driver's side. I would like to replace the mirror itself without replacing the entire mirror casing. Is that possible, and how is the mirror removed to do it? Thanks, I haven't seen any threads that cover this.
Old Jul 22, 2011 | 01:19 PM
Old_School's Avatar
Old_School
AFAIK, you have to replace the whole think on the OEM ones... however, they do make aftermarket ones where just the mirror pops out.
Old Jul 22, 2011 | 03:49 PM
hydrashocker's Avatar
hydrashocker
People have replaced just the glass and you can get it at the dealer. I think they just pop out but lining them up is a b!tch. I popped one out at the junk yard a few weeks ago just to see. There are 2 wires that attach defrost mirrors is equipped. The power motor is behind the glass.
Old Jul 22, 2011 | 05:30 PM
Compactc9's Avatar
Compactc9
I accidentally broke the passenger side mirror glass, and was able to buy just the glass panel from the dealer, but I have the large heated mirrors, but I would suspect this is true for all of them.
Old Jul 22, 2011 | 05:37 PM
WhiteWidow00's Avatar
WhiteWidow00
Yes you can buy just the glass whether it's heated or not because the heated element is in the housing itself and has nothing to do with the glass.
Old Jul 22, 2011 | 06:40 PM
Compactc9's Avatar
Compactc9
The heater on mine is in the plastic back on the mirror. The glass panel comes with the plastic back plate on it that snaps onto the tilt motor bracket in the housing. To take it out all I did was get my fingers behind the mirror panel and pull it out of the housing slowly and it un-snaps. Then the new one you just line it up and push it back in and it snaps in. Then if the mirror is heated the wires connect to the back of the mirror. At least as far as I know, they don't come as just a piece of glass, all of the ones I have seen had the plastic back.
Old Jul 22, 2011 | 07:40 PM
stonebridge
You folks are great. This is the most helpful Dodge site online. Thanks, I appreciate the help.
Old Jul 28, 2011 | 07:29 PM
stonebridge
Talking Dastardly deed is done
Thanks for your help everyone. I've never been left hanging here for an answer to a question. Two fingernails, a small amount of blood and a few curse words still hanging in the air somewhere over Lake Michigan, and it is done. The black frame casing DOES pop out after some careful prying, and snaps back in after the old cracked mirror is removed in pieces. It's a bit of a pain to remove because the entire original mirror is backed with 2-sided sticky (very) tape, but the total cost was about $10, as opposed to $125 at the dealership. Dodge Forum rocks!
Old Jul 28, 2011 | 08:14 PM
Old_School's Avatar
Old_School
Glad to hear it all worked out... i see your from new oxford? im over here in dover... small world.
Old Jul 28, 2011 | 09:28 PM
hydrashocker
Good to hear you got-r-done and only $10 bucks too!
But your broke 2 nails, cursed some, and drew blood. But you forgot to take pictures and notes of these things......
