air problem
Try removing the "0" at the front of the part number.
For instance, Part number 05003134AA could actually read 5003134AA without the front "0". This is true on both those part numbers. Your probably better off going to a junk yard or dealer anyway.
So after a week the web site I bought the lever from emailed me saying it was discontinued I finally found a junk yard where I could take the part off noticing how easy the mode doors moved I knew something was wrong with mine I put the lever on mine still no go so I cleaned greased as much as possible the gears still no so I sanded the hole on two of the gears perfect lots of trouble but I learned alot almost got it together
