Water leak! Help!
Old Jul 26, 2011 | 01:21 PM
DURANGO24's Avatar
DURANGO24
Exclamation Water leak! Help!
I have a coolant leak on my 98 durgano. I think its coming from in between the tranny and the motor. I think its the freeze plug(s) but im not sure. Or maybe a crack in the intake? Has anyone had this problem?
I have to fll it up before i go anywhere. It doesn't overheat unless i forget to fill it up. It drips more than the a/c drip does.
Please help me to figure out what this is and maybe how much it would be to fix it?
Thanks
Old Jul 26, 2011 | 02:31 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
id 2nd the freeze plug diagnosis personally, i do remember another member having that problem not too long ago, might try searching to see what he did
Old Jul 27, 2011 | 07:34 AM
Duranged408's Avatar
Duranged408
Before you dive into the rear "impossible to reach" plugs, check your cabin air box drain first (maybe even your heatercore lines at the firewall). You will see a plastic outlet on the firewall near the passenger side header above the heat sheild that when the core leaks, can be confused as a freeze plug.
( i have a body lift with removed splash gaurds so it wont be as easy to see)
