1998 Dodge Durango A/C leak coming from evap!
Old Jul 29, 2011 | 07:59 PM
chrisiacovetti's Avatar
chrisiacovetti
Default 1998 Dodge Durango A/C leak coming from evap!
Hello everyone!
I am new to this site.
I purchased a 98 durango and really like it .. But...
Its a costly vehicle!!
Things I had to replace recently were the transfer case and the a/c compressor. Both I did myself. (The transfer case was a major pain!!)
I really want to replace the evap myself. I heard its on the inside of the fire wall? Not sure how to access it. Does anybody know how to access it exactly? I really want to do the work because it will be right!
If anyone has a complete disassembly instruction on this I would be truly grateful!!!
I also need an abs pump.. AYE! Just morrrre money to spend!!! That one is easy tho!
If anyone can help me with the evap situation I would appreciate it!
Thank you guys!!
Chris
Old Jul 29, 2011 | 08:05 PM
pkucan's Avatar
pkucan
Originally Posted by chrisiacovetti
Hello everyone!
Thank you guys!!
Chris
I believe you have pull the dash!
Old Jul 30, 2011 | 01:54 AM
samnbensdad's Avatar
samnbensdad
You are correct; the dash has to be pulled. This is easier said than done. If you pay a shop to do it, you'll be paying about 8 hours labor. I recommend replacing the heater core while you are in there. You don't want to take the dash apart more than once.
Old Jul 30, 2011 | 03:08 AM
topdogcustoms's Avatar
topdogcustoms
if it was me i would change the blower motor along with the evap and heater core
Old Jul 30, 2011 | 03:50 PM
hydrashocker's Avatar
hydrashocker
First let me welcome you to the gang!
How do you know you need to replace the ABS pump?
We can help you out a lot around here with just about any issue. Just ring in a new thread for each issue and we'll help you as needed. Remember to use the Advanced Search option because there is many issues that have been covered and LOTS of information here to help you along your ownership. Remember to search in the 1st generation Durango section to help you find your topics.
Old Jul 30, 2011 | 11:55 PM
IndyDurango's Avatar
IndyDurango
You've spent a lot of money already? Well time to fork over some more. The evap, core, fan = $850 in parts and $500 in labor on the cheap. If you DIY, it takes all weekend and make sure you bag and label ALL of the parts you remove. There will be many many more than you will expect.
Install instructions are here on the forum in a dozen threads. Use the search.
IndyDurango
