Durango 2000
Old Aug 2, 2011 | 03:05 AM
victoriaclontz's Avatar
victoriaclontz
Default Durango 2000
i just got this car from my brother. the durango started to overheat so i pulled over and popped the hood. the radiator(i think what ever is right there at the grill) on the left hand side has little holes on the side. how do i fix those? do i need a whole new radiator?
Old Aug 2, 2011 | 08:48 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if the radiator is leaking it needs to be replaced
Old Aug 2, 2011 | 10:04 PM
hydrashocker's Avatar
hydrashocker
Yes the radiator is on the front grill.
If it is leaking from it then most likely you need a new radiator, however if it is only leaking where the hose is then it could just be a hose or a bad clamp. Make sure you do not overheat it or you will take out the head gaskets!
PS<-----Now if it is the hard lines going into the radiator that could be different. If you could take a couple of pictures of it we can further assist you.
