Help with radio install no sound?
Old Aug 14, 2011 | 02:27 PM
on1wheel01's Avatar
on1wheel01
Default Help with radio install no sound?
Well trying to install my alpine deck. I got the wiring kit and such. I connected all the wires that color match. It does have the infinity sound system, the amp plug in and another wire connector with 2 wires in it dont match up to anything. So do I need to do something to make it work?
Old Aug 14, 2011 | 05:52 PM
on1wheel01's Avatar
on1wheel01
Nobody?
I am going to run a 4 ch amp to them when I order the new speakers and amp(when I pick em out). But still would like it to work now
Old Aug 14, 2011 | 09:04 PM
adukart's Avatar
adukart
Check to see if you need an adapter. I know the 2006 pickups with the amplified infinity system do.
Old Aug 15, 2011 | 07:23 AM
on1wheel01's Avatar
on1wheel01
Well I said screw it and just started running new wires for a 4 channel. Another ? does anyone know the deepest speaker that will fit. im lookin at cadence comps they have a mounting depth of 3". Will they fit. May have to make some mdf spacers.
Old Aug 15, 2011 | 09:02 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if you save the sleeves from the stock speakers you can fit a regular depth speaker (w/e that is) otherwise you need to buy the crappy shallow mounts
