Differential Additive
2001 Durango R/T 5.9
Has twist **** automatic switch for switching between different
modes of AWD-4WD ect.
I was going to be changing out the differential fluids, but the dealership said they do not had the additive for the rear differential.
What is the best alternative.
Thanks..
Thanks..
yup any auto store should have the additive for you, but make sure you have a limited slip before spending the money on it, either get a build sheet from the dealer or check it yourself
also even if the dealer doesnt have it they should have exactly 0 problems getting it for you.
