under hood fuse/relay box
Old Aug 27, 2011 | 11:59 AM
moparmuscle's Avatar
moparmuscle
Exclamation under hood fuse/relay box
i either have a bad connection or corrosion inside the bottom of my fuse box where all the connections are my d will start sometimes and sometimes it will come on all fine and when i turn the key to start it all the lights and hazards start blinking and dont stop also the starter relay clicks constantly until i pop the hood and hit the side of the fuse box i have checked all wires going into box and are fine and replaced the relay i need to kno how much of a pain in the a** it is to rip apart the box and possibly replace it bc the mounts are broke off of it
Old Aug 27, 2011 | 03:38 PM
hydrashocker's Avatar
hydrashocker
Now that is a PITA!
Can you see what is relay is exactly clicking in the PDC when you are having the issue, could help you in fixing yours.
Not sure if they just plug into a harness that is wet or what.
Old Aug 28, 2011 | 12:50 AM
adukart's Avatar
adukart
Just make sure you take photos along the way to refer to when putting the puzzle back together.
