Disconnecting O2 Sensor electrical connector 2001 4.7 Durango
Old Sep 8, 2011 | 11:25 PM
vstanford's Avatar
vstanford
Default Disconnecting O2 Sensor electrical connector 2001 4.7 Durango
I need to replace the downstream O2 Sensor on my 2001, 4.7 L, 2WD Durango. But, I cannot get the electrical connector apart. How is this accomplished?
The connector has an orange part that slides. I slide it and still can't get the connector apart. What is the secret?
I have searched the forum but evidently I do not use the proper search words. Can't find anything about this.
Thanks
Old Sep 9, 2011 | 05:15 PM
hydrashocker's Avatar
hydrashocker
The orange slide must be fully removed first.
Then you have to slightly pry each side arm up together, then pull the harness apart.
Old Sep 9, 2011 | 05:18 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you have to slide the red clip and then squeeze on another tab that is there, its a double locking mechanism iirc.
