2000 durango 5.9 having troubles running
Old Sep 12, 2011 | 01:04 AM
rktbm21's Avatar
rktbm21
Default 2000 durango 5.9 having troubles running
i have a 2000 Durango its started having problems when i start it up it will just dies. i usually have to restart it 5 times before it will run right and also when i start it and begin driving it doesnt shift until it reaches 3500 rpms but after that it will shift just fine. i just had the transmission fluid changed. any suggestions on how to fix these problems
Old Sep 12, 2011 | 10:08 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
for the shifting issues i would look into the transmission output speed sensor, check the IAC on the starting issues
Old Sep 12, 2011 | 10:56 PM
adukart's Avatar
adukart
Did they use the right tranny fluid, just a thought. Also if the IAC and Tb cleaning doesn't fix the start issue do a tune-up.
Old Sep 13, 2011 | 12:10 PM
hydrashocker's Avatar
hydrashocker
Could need the TV cable adjusted. Also replace your spark plugs with Champion Copper and gap them at .040 before install and that should help the start.
