At last, it runs better!!
Once again, it's my dad's vehicle and i know hes not gonna buy different plugs and do this all over again. If it was my truck, yeah they'd be bought and ready to go in first thing tommorow morning lol.
I like working on these trucks though. I like how they're sorta oldskool under the hood. Not much except an engine and a few hoses. Nothing like my mom's explorer. That things a nightmare under the hood.
My dad replaced the cap and rotor 40,000 miles ago and he said he turned it and thought he advanced it but turned it the wrong way and claims he retarded it. So your saying that turning the distributor does absolutly nothing on these engines?
Also, it came with champion platinum plugs from the factory so isn't that what should go in?
And, we did the parts over 2 days. The first day i put in the spark plugs and my dad turned the distributor to advance the timing..or so we thought. Spark plugs that came out were fine, i just said replace them since we're doing all the other parts. We fired it up and he turned the distributor to advance it. He turned it until the motor shut off. He turned it back a hair and i started it up. It cranked over quick, and ran good so he tightened the srew back up and we took it for a ride. It sounded different, the tone of the engine changed and its ALOT quieter and smoother. And like i said it felt and sounded different under WOT. So, if turning the distributor doesnt do anything, than how did it run so different? It must do something..
Next day we put the wires, cap and rotor on and they really made a difference. The gas guage doesnt seem to move as much, and i notice that its more responsive and under load the motor feels and sounds better.
But does the PCM learn that the distributor was turned and then compensate for that?
No, Platinum plugs are not OEM. OEM is Champion Copper plugs, in fact you can look under the hood on one of the two labels and it will show you the factory plug number it needs and the gap at .040.
Yes it compensates for some movement, but it can only compensate for so much. All the inputs change the timing also including out side abundant temperature and many other things. It's not like it's going to fix it's self because you pulled it out of parameter so it can't. It's tough love ok, you screwed it up and now you need to put it back as close as you can, it's called doing it by OBD or manually getting it close by indexing in which I already gave you the link.
Not to be an *****, but do what you want, seriously I'm tired of typing such long responses to try to prove a point that is out of the normal mechanical range.
also the truck did NOT come from the factory with platinum plugs in it, it came with champion coppers in it when brand new.
the only way you go through plugs in 10k (even coppers) is if you are running the wrong heat range plug in the engine.
My dad had a few hopped up fords back in the 70s, and he used to own a timing light, so he knows what he's talking about with the timing..he said he would turn the distributor and it would begin to sound different, and if it pinged, then back off a little. And he'd point the light at the damper and check what the engine was at. I'm not implying you dont know what your talking about hydrashocker, you put out some good info. I'll admit that i think my dad is stuck in the '70s. He knows the tricks from back then, when there wasnt such a thing as a PCM, and tuning a car was all by ear
In any case, the plugs you selected are way to hot for your engine. Step it down a bit to the regular champion copper cores and save your engines internals before its too late. If you need to go that far with it then have fun selling it for $800 because it has a blown engine.
Even if your dad won't go out and buy the correct plugs, then go out and buy them yourself. It will cost you $20 for 8 copper core plugs.
alright well thanks for the advice guys, i really had no idea that platinums were bad for these engines, and of corse i found out after we bought them. But what about iridium plugs? DO they work in the Magnums? I know they do last a bit longer than a copper plug..
