Alternator pulley not lined up with other pulleys
Old Sep 20, 2011 | 09:20 AM
noman's Avatar
noman
Default Alternator pulley not lined up with other pulleys
My belt has been sqealing lately. When I was looking at the belt I noticed
the alternator pulley sits back a 1/8in or more toward the motor. Which causes the belt to not be all the way on the pulley between the alternator and ac unit. I had the alternator off when I changed the plenum gasket.
Did I forget something or do something wrong when I reinstalled the alternator? And could this cause the belt to squeal?
Old Sep 20, 2011 | 11:18 AM
hydrashocker's Avatar
hydrashocker
I have seen shim's in the past that look like a small piece of pipe that shim the corresponding motor into the right spot. Further it could be that if it was a replacement that it could not have been pressed right from the manufacture. Please take a picture of it from all angles so we can have a good look and see what would be the best option to help you align it. It could be as simple as pulling the pulley back off just a tad.
Old Sep 20, 2011 | 06:39 PM
noman's Avatar
noman
I'll get some pictures it may take a couple days.
