Really f&^@(*g anoying
Old Sep 22, 2011 | 09:28 AM
Dirtrango's Avatar
Dirtrango
Default Really f&^@(*g anoying
OK 1999 rango 4x4 My dash says i'm in PT 4 wheel but lever is in 2 wheel. What the heck is going on and how do i fix it????
Old Sep 22, 2011 | 09:45 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
is the truck actually in 2wd? make a sharp turn on dry pavement and see if the front end binds up on you, if so then it is actually in 4wd and you need to crawl underneath and check the linkage, if it is NOT in 4wd then you probably have a bad range switch on the t-case which senses where the mechanical parts are positioned and as such what gear you are in.(4wd,2wd, exct)
Old Sep 22, 2011 | 09:59 AM
Dirtrango's Avatar
Dirtrango
Ok i'll check at lunch time provided it stops raining.
