'99 Durango 5.9 Front End Vibration...
Old Sep 30, 2011 | 09:38 AM
johnmac3374's Avatar
johnmac3374
Default '99 Durango 5.9 Front End Vibration...
1999 Dodge Durango 5.9l (114000 miles).
The passed 2 months I have been experiencing a bad vibration in my front end. I can hear it at 10-15 mph, 15 mph + I can feel it. When I get up to
55 mph+, everything vibrates, the steering wheel, dash, floor... And the noise gets very loud.
Heres the kicker, when I turn right (exit ramp), It completely goes away. Absolutely no vibration or noise....
When I was in a parking lot I turned full right for a 180deg with my window down. I could hear chirping. sounded like the rubber of the tire on the pavement...
I had a mechanic ride with me. He said it feels and sounds like wheel bearing going bad.
I replaced both driver side and passenger side bearings/hub. Problem did not go away...
Any advice would be greatly appreciated.
Thanks,
-John
Old Sep 30, 2011 | 07:22 PM
Dman98's Avatar
Dman98
I have a similiar issue, I'll post if I find the answer. Btw, a wheel alignment, balancing and rotating the tires didn't help.
Old Oct 3, 2011 | 04:49 PM
hydrashocker's Avatar
hydrashocker
Could be a CV joint or a U-joint. With turning and the sound goes away I would try the CV first I think.
Old Oct 3, 2011 | 06:07 PM
Dman98's Avatar
Dman98
All the u joints are new, as well as the drivers side cv axle. I'm hoping to find exactly what the problem is without changing a whole lot of parts. That way if it happens again, I'll know what to replace.
Old Oct 4, 2011 | 10:11 AM
noman's Avatar
noman
Did you look to see if the steering was loose. Maybe the control arm or tie rods.
