Durango 4.7 Exhaust Manifold Bolt Specs
Old Oct 27, 2011 | 08:24 PM
jpetro1's Avatar
jpetro1
Default Durango 4.7 Exhaust Manifold Bolt Specs
The rear upper right side manifold bolt came out on my 2000 Durango 4.7L. After reading all the posts on manifold issues I was sure this had broken but luckily it apparently vibrated out. After searching all over for thread data on these bolts, I bought a bolt from the dealer and here it is. The 4.7 uses a combination of bolts and studs to attach the manifold. The bolt I got from the dealer cost 1.95 plus tax. It is M8 x 1.25 x 50mm. I have seen a few posts stating that this bolt is a 5/16 but this one is not. You can probably get a 5/16 bolt to thread in but it will tear up the existing threads on the block.
Old Oct 28, 2011 | 09:12 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
https://dodgeforum.com/forum/dodge-d...s-section.html
ill move it for your this time.
