Just ran seafoam, got to read this!
Old Nov 8, 2011 | 08:53 PM
  #21
samnbensdad's Avatar
samnbensdad
Originally Posted by OffTheTimeline
Shrps, so would it not really matter if I gassed @ chevron (with techronŽ lol) or @ arco where I can save sometimes more than ten cents per gallon? I always try to gas @ chevron since I moved to the states, back home I always gassed @ mobil... and now I am itching to pick up some seafoam now! :-)
These are the big things to watch for ...
*Ethanol content
*Above ground fuel tanks
*Cleanliness of pumps
*I personally stay away from older/aging stations too because you never know the condition of their fuel tanks. It's very expensive to maintain those tanks.
*A lot of people also avoid stations while they are being refueled due to the sediment in the tanks being stirred up (even though each nozzle has a filter).
Old Nov 8, 2011 | 09:22 PM
  #22
RollerRed's Avatar
RollerRed
*Ethanol content
*A lot of people also avoid stations while they are being refueled due to the sediment in the tanks being stirred up (even though each nozzle gas a filter).
Amen
++1 on that.
I personally use cheveron mainly because they are the newest station in town(just built 2 years ago) plus tecron(sp?).
Old Nov 8, 2011 | 09:23 PM
  #23
RollerRed's Avatar
RollerRed
Originally Posted by adukart
When my plenum finally goes I'm definitely doing the kegger. There is a guy who sells on the forums and ebay port and polished tb's. He does a 50mm and a 52mm, the 50 is like $90 and the 52 about $140 plus you can get another $25 back if you send him your old one. It looks like he does good quality work, he also uses laser cut throttle blades.
Who is this?
I would want the 50 I am sure, unless the 52 really is worth the extra $50...That would be sweet. I could pull that and then just cut the kegger up! Win win in my book...
Old Nov 8, 2011 | 10:19 PM
  #24
adukart's Avatar
adukart
Here's his email, brianwhiteley1974@yahoo.com I think his handle on ebay is blkdktrt. Here is a link to another forum were he sells them http://www.thespeedfreaks.net/showthread.php?t=5212. Doesn't hurt to get specifics.
Old Nov 8, 2011 | 10:47 PM
  #25
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
correct, as long as the tanks are not leaking and getting water into them you will mos tlikely not have problems, i personally buy from the cheapest station that does not have ethanol in their gas.
*Ethanol content
yup ethanol content and leaking tanks are the two big things to look out for.
i dont care if they are being fueled at the time bc, as you said, they have filters on the pumps. also i will stay away from gas station in the local flood plain for a while after heavy rains, especially when they actually flood.
Old Nov 8, 2011 | 11:57 PM
  #26
RollerRed's Avatar
RollerRed
I cant seem to find this guy on ebay anymore...is this his thing? This guy says he used to build and do them but can anymore.
What do you think here?
http://www.ebay.com/itm/Instructions...sories&vxp=mtr
Old Nov 9, 2011 | 09:33 AM
  #27
Jason Van Order's Avatar
Jason Van Order
Im not sure about other states but i think here in michigan if a station uses steel tanks the have to be replaced every 10 years. If the use the poly tanks or whatever they are they can leave them in longer but the have a very good system to detect leaks going into and out of the tank. So if the station is less than say 15 years old you can be pretty sure the tanks dont leak
Old Nov 9, 2011 | 01:05 PM
  #28
adukart's Avatar
adukart
Really he can't do them anymore, dang. I talked to him this spring and he was still doing them then, I had some stuff come up and ended up not being able to order one.
Here check out this company http://www.thefastman.com/Throttlebodies5x.asp many members on here have gotten throttle bodies from them and seem to happy with it.
