Carbed 5.2
Old Nov 29, 2011 | 02:45 PM
Dirtrango's Avatar
Dirtrango
Default Carbed 5.2
How many here have a carbed engine. I do and wish it was a TB system.
Old Nov 29, 2011 | 04:05 PM
ZCR1's Avatar
ZCR1
Could you post a picture of this carbed engine? Just so you know, no Durango of any year was carbed from the factory. The 5.2, 5.9 and 4.7's were all multi-port fuel injected.
Old Nov 29, 2011 | 04:59 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
when did you do the engine swap that you have a carbed engine??
as stated all Durangos left the factory with multi-port fuel injection
Old Nov 29, 2011 | 09:12 PM
hydrashocker's Avatar
hydrashocker
And what did you do with the PCM and system if you changed it over?
Old Nov 29, 2011 | 09:14 PM
adukart's Avatar
adukart
Are you sure you didn't misidentify? This just sounds weird.
Old Nov 29, 2011 | 09:22 PM
ZCR1's Avatar
ZCR1
I think this is a case of simple mis-identification. Most newer engines have a single, side or front mounted throttle body like the 4.7, hemi's, Chevy LSx, Ford 5.x...
The 5.2 and 5.9 have a top mounted TB that at a glance or unaccustomed eye looks to be a traditional carb setup.
Old Nov 29, 2011 | 09:44 PM
TurboStixx's Avatar
TurboStixx
my engine is carbed...
Old Nov 29, 2011 | 09:47 PM
adukart's Avatar
adukart
PLEASE POST SOME PICS!!!!! No Durango ever came from the factory with carburation. Where's your pcm? How do your gauges still work correctly?ect. Not saying the PO didn't switch it but an earthquake has a better chance of build a house.
Old Nov 29, 2011 | 10:06 PM
TurboStixx's Avatar
TurboStixx
oooooh we are talking about our D's, so sorry, was talking about my Kawasaki Spectre 750 :-) oops my bad guys, LMAO! Definitely TBed here, and what did I do with my PCM? No clue where it went, it just went :-P
Old Nov 29, 2011 | 11:16 PM
ZCR1's Avatar
ZCR1
Well you could rig a mount for the tps on the carb, cap the iac plug, install resistor jumpers in the injector plugs, install a 7.5 psi fuel pressure regulator, and install a stand alone voltage oscillation unit on the upstream O2 sensor........
