2002 Durango v8 stalling
Old Dec 3, 2011 | 02:56 PM
petea209's Avatar
petea209
Default 2002 Durango v8 stalling
I have a durango v8 2002 idles fine and drives fine down roads but if i rev it up and remove foot the rpms drop untill it stalls also happens at lights. no engine lights are on at this time but I HAVE KNOW IDEAL HOW TO FIX THE STALLING any help is greatly appreciated.
Old Dec 3, 2011 | 03:33 PM
that_guy's Avatar
that_guy
it's either a bad battery or bad connection to battery. check the terminals and make sure they're clean and tight
Old Dec 3, 2011 | 05:08 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would start by cleaning the tb really good, including the IAC, if that doesnt do it, i would replace the IAC, and if that still doesnt do it the TPS would be my next guess, the battery is unlikely if it come down to an idle fine at stop lights.
as i understand the situation you can come up to a stoplight, and if you rev the engine(while sitting at the light) it will die when you let off the gas
if it always dies when you stop or idle then check the battery/connections.
